Memory for the displayed object could not be allocated which may be due to the system running low on memory. This will result in incorrect network address translation operations.
Check the scalability limit and compare this with the current configurations. Reducing the system configuration may help reclaim memory. Once sufficient system memory is reclaimed, it is recommended that netTools process be restarted for internal state to be fully rebuilt.
Error
Memory allocation failed when trying to allocate a %obj% structure of size %size%.
Name | Type |
obj | String |
size | uInt32 |
